Best way to reset the ecu
1 reading
16K views 8 replies 6 participants last post by  BrendaF
#1 ·
Hi everyone, could someone tell me the best and safest way to reset my 13reg Evoque please. Thanks
#4 ·
Pulling a fuse will only disconnect the items on that circuit, depends what you are trying to achieve?
#6 ·
As above, however I would suggest 30 mins disconnected - we had an Audi which required well over 5 mins to discharge residual charge.
Not sure if connecting both leads is a good idea, maybe an urban myth, but there are suggestions it can cause damage?
#8 ·
Once you’d disconnected the battery did you hold the +ve and -ve leads together. This allows capacitors in the various units around the car to discharge.
